2021+ Gen 3 Raptor OFFICIAL Eibach Spring Kits Now Available!
JayRods
Manteca Ca
The hard part is jacking the truck up high enough to get the spring out. Unless you have shop lift.
nbleak21
CT
I couldn't get my rear axle off the ground yesterday trying to jack up from the frame with the HF Badlands jack. I was close but needed a little bit extra. It sounds like I'd need to have a shop go ahead and do it. Thanks.
JayRods
Manteca Ca
Ya it's crazy how high it will go up before the rear tires leve the ground.
BoostCreep
SoCal
You could always jack it up from the diff to get the tires off the ground, take the wheels/tires off, jack up the frame, and then lower the axle, you should have enough clearance that way. But yea, the amount of rear droop travel is shocking.
adubbennett
Alabama
Does anyone have measurements of all four fenders after installing the front springs only? I have the eibach 1in fronts that go in next Thursday but have so much rake that I'm contemplating the 1.5 RPG now. IMG_0820.jpeg
