2020 suspension “squeal”
FordTechOne
Detroit
Checking the fender liners once again I found this on the passenger side:
I don’t know if this is related or if im just lucky enough to have discovered yet another issue with the truck
You bought it used, no telling what may have occurred with the previous owner. I see it all the time, used vehicles are always a risk, and CarFax is not liable for accidents/damage that isn’t reported.
Are the tires the factory BGG KO2 or something else? Even tires with the same size specs can have different tread patterns that may cause rubbing in certain applications. Otherwise, something is damaged.
WNCgen2
WNCgen2
North Carolina
Not that it matters, but does it also do it in 4wd? Doesn't sound like anything related to 4wd, but its a quick test. Does it do it on all pavement types? Does it happen turning both left and right? I think what thatjeepguy is referring to isn't the tire rubbing on any component on the truck but a wide grippy tire making a noise when being turned at low speeds on the pavement.
I haven’t tried it in 4WD and it’s most prevalent at speeds under 10mph on regular pavement.
Space Ghost
FL
Sounds more like a spring squeak noise, i had rubbing before on my ranger and it was a different noise.
thatJeepguy
GA
Ive checked in the wheel wells and there is no evidence of scrubbing anywhere. Why would the factory 35s scrub and only with the wheel at like 30% lock?
Tires scrubbing on the pavement not the wheel well.
