Ruby
Just got my key today. Works Flawlessly on my 2017. Programming is possible to do yourself as long as you have both original keys. Ive included instructions below on how to program your new fob. Both links I've posted earlier work and are correct. Ive added them below aswell. You need to purchase both parts.
Key Fob:
17-18 Ford F-150 RAPTOR Smart Keyless Remote Key Entry F150 Fob Transmitter OEM | eBay
Key blade:
New 164-R8168 OEM Proxy Smart Key Blade Emergency Insert Replacement for Ford
PROGRAMMING NEW KEY FOB
1. Gather BOTH programmed keys and your new un programmed key. Start inside vehicle with vehicle turned off.
2. Place the first programmed key in the backup position
3. Press Start\Stop button
4. Count to three maybe four seconds (one one thousand, two one thousand, three one thousand)
5. Press Start\Stop button
6. Swap first programmed key with second programmed key (quickly)
7. Press Start\Stop button
8. Count to three maybe four seconds (one one thousand, two one thousand, three one thousand)
9. Press Start\Stop button
10. Swap second programmed key with the un-programmed key (quickly)
11. Press Start\Stop button
12. Door locks will cycle and dashboard light up and dashboard counsel stated “Key Programming Successful”
Key Fob:
Key blade:
