2018 B&O replacement build
Kyle@Apollo-Optics
San Antonio,TX
Most of us don’t run a center channel. I know I won’t be. I’m still acquiring my gear. Mosconi DSP and Subs are all that’s left for me and I will start my build.
Kbobk
I thought the center/dash speaker was necessary for the navigation sound. If it’s not needed I’d prefer to disable it and not bother.
BIGDJE
OC, CALI
i kept factory center and have a separate channel from amp for it since the zen tv let us keeping using it
BIGDJE
OC, CALI
So how did this install turn out? I'm dying to see this amp rack all wired up and mounted.
Sent from my SM-N960U using Tapatalk
sounds amazing other then 2 tweeters in back doors looks 100% factory unless you fold down back seat and see the 2 12s and box the amps are in that space behind rear seat thats at a angle .
will take some pics all done
dhmcfadin
I"ve got another question for you. how did you integrate the SMD voltmeter into your distro block? I can't tell from the photo.
The SMD disto block comes with the voltmeter built in. It has a positive and negative wire that you wire into each distro block.
Quick
Where are the crossovers mounted for the rear doors? How did you wire up the tweeters/woofers?
I am looking to do something similar and really want to avoid running wire through the door jams.
