- Joined
- Jan 29, 2012
- Posts
- 1,088
- Reaction score
- 582
Man that truck is shiny
How many amps does each light draw? Trying to figure out switch arrangement.
Each light is roughly 1amp. The instructions come with the diagram of how much amps each switch can handle
Not sure I would want to use garbage bags as filters
A more exact figure on the instructions might be helpful. I know lots of guys want to save the high amp switches for light bars. Would be good to know if you can get away with 5 lights, for example, on a 5 amp switch.
What's the recommend way to join the wires together if you're running 6 of them, for example, to one switch? Just twist and heat shrink or are people using something more complicated? I heard someone was just using a wire nut and a ton of electrical tape, but was wondering if there's a better way.
3 pair of lights is right around 8 amps. My installer checked them before wiring them up to the upfitter switches because I wanted to wire 2 pair of ambers to switch 3 and 3 pair of white to switch 4 to save 1 and 2 for bigger bars.
X
Would plastic cut from a gallon jug used for milk work? I realized after I posted that there is no heat issue with leds and the thin plastic would not be affected
Yes of course. They are IP68 water rating.
