2013 Stock Black HIDs - $350 Retrofit!
infinitereality
infinitereality
SLC IR/8
Louisiana
Apparently the H13 module from DDM was the issue, not a single issue since installing the Morimoto module.
Got to really try these things out this weekend, the light spread is 10x better than the reflector housings it's unreal. I couldn't be happier and with the extra 20w of power, even more light.
infinitereality
infinitereality
SLC IR/8
Louisiana
Just updating again, all is good with my lighting. I hate DDM with a passion, different color H13 bulbs, crappy module. I should have done all of this from the beginning.
infinitereality
infinitereality
SLC IR/8
Louisiana
Exactly! Used housings, retrofit some D2S bulbs with ballasts along with the Morimoto harness and works. Plus extra 20w of HID light output is nice too!
Danactive
I'm Back!
Syracuse, NY
so quick question... i just bought TRS 35 watt hid h13 kit if i were to buy the same 2013 headlight housings like you did would i be able to just plug them in and go? im still confused on the whole 2013 head lights and what really needs to be done for them to be installed correctly.
infinitereality
infinitereality
SLC IR/8
Louisiana
Unfortunately not, the new light use a different bulb. But since yours are Pnp you could just buy a different bulb size and should be gold
