2013 Headlight Bulbs
Jordan@Apollo-Optics
aka <b><font color='darkorange'>LSUstang05</font><
I honestly just want my headlights to have a wider throw. The narrow coverage they have stock seems ridiculous based on how big the vehicle is IMO. Whenever I take a sharp turn I'm always turning into a dark spot rather than a spot that is covered by the headlights.
RajunCajun37
Banned
HID and LED and Plasma bulbs and some Xenon bulbs in non-projection housing is for the birds.
Stock halogen bulb replacement is tough. Only the Philips Extreme Vision 100's help. Little more light, little brighter, little whiter and better placement and focus. I'm happy with them cause it cost me $40. Hard to find in the H13 cause it's a German made bulb. Get the 100's not the 80's
krypt0
USA
Excellent write up Krypt0.
I like those bulbs, but I would hate to spend that much for a test. What do you think abou these as a Korean alternative ?
BLESK D3S HID BULBS
I'm sure they would work ok. Plan on either ordering two sets or keeping your OEM bulbs handy though. Cheap bulbs like to flicker quite a bit and tend to have a very short life.
Keep us updated if you decide to buy and install them though.
ARH1956
NE Alabama
Sadly the only way to get better width is a different projector. It's a shame Ford didn't develop a top shelf, D2S compatible projector with a wide beam for the F150!
InMotionJosh
Great write up!
One question. The lights look purple in the picture. Is that just from the photography innacuracy or are they really that purplish color?
I also hate the yellowish light output of the stock 13 projectors and would like a crisp bluish white light.
krypt0
USA
Great write up!
The purple color is fairly close to what they looked like at the time those pictures were taken.
After a few weeks of use, they lost most of the purple tint and now are a very nice looking white with a bit of blue.
There is however a slightly annoying downside to these PIAA bulbs. When the outside temperature is cold, occasionally one of the bulbs won't ignite the first time and you need to turn the headlights off, then back on. As you can imagine, it's a pain in the butt to have to check both bulbs are on every time you use the headlights. Too bad you don't get a warning light/notice if one of the headlight bulbs isn't working.
This seems to be a low voltage problem, but because I never had that issue with OEM bulbs, I'm guessing it probably is the PIAA bulbs.
krypt0
USA
UPDATE:
Ever since I installed these PIAA bulbs a few months ago, I've been having intermittent problems with one (or both) of the bulbs not igniting when turned on.
This forced me to physically get out of the truck each time I turned the headlight switch on and make sure they both worked.
On a recent road trip out of my home state, it took 3-4 tries before either of the bulbs ignited. This really concerned me and made my decision to revert back to OEM bulbs.
I really did like the light output color of the PIAA's, but I can't trust them for any sort of reliability.
Overall, I would be very hesitant to recommend these to anyone due to apparent cheap or weak ignitors in the PIAA bulbs.
