Matts6foot8
So I was changing out spark plugs and coil boots after about 40,000 miles and the plugs had normal wear. What concerns me is while I was changing out the boots and coil wire a few of the resistor "pellets" would not drop out of the coil. Some were corroded in and after further research some of them had gotten so hot that they had charred the inner plastic ribs that hold the resistor. I was able to get the new ones back in the coil but some of them were not perfectly straight like they should be. My question is eventually will these resistors not being dead set perfect in line with the coil wire in the boot will this cause further problems down the road? The truck runs fine now with no misfires yet. Like I said before the spark plugs had normal Brown color when I pulled them they did not look like they were getting too hot but the coil resistors were getting too hot. The old plugs also had the right Gap at .42.
With all this being said and if I have to get all new ignition coils does anyone recommend a reputable brand? I am loyal to motorcraft but I also believe in other reputable brands if it can save money without losing quality.
