NickPic83
i got my tails done at a good body shop thats local to me thats done work for me before. cahrged me $100 which is pretty cheap i think. its not that hard to do either but i rather a pro do it for the money. they did the hood on my last truck
dont mind the ugly grill that was a mistake, i changed it lol
there is how to's to tint tails too if u wanna look it up
yes is u F up u just peel it off. what i did was clean the emblem then use masking tape and make a square around the oval, then tape some newspaper on the bumper and rest of the tail gate. then take a small peice of tape and put it in the middle of the ford in the oval. let a corner stick up. also taped over the camera nicely. then i took a heat gun and made the chrome warm not hot. srayed first coat nice and even, overlapping each pass and not staying in one spot. i then slowly went back and forth with the heatgun on low to help speed up the cureing. just when it seemed to be almost fully dry i did the next coat. so on the 4th coat i sprayed it the same way and let it dry be itself. when it was 85-90% dry i started taking everything off. i started with the squared around the emblem. took off tape and started picking at the corner once i started it i wnet SLOW and it peeled right off. then i took off the small peice on the ford. that gave me a starting point to peel. peel that slowly as well. then took off tape from camera and took off test of tape and paper. then i applied the new decal with the heat gun
