17" Aftermarket Wheels that fit Gen2 without any modifications
R3ggi3Raptor
Salt Lake City, UT
Hello,
I am trying to find 17" wheels that will fit on my 2018 Gen2 Raptor without any modifications whatsoever. I would like to use the factory tires and not have to trim, level, or lift. I am trying to retain the factory ride as best as possible. Anyone had luck?
Thanks!
@Pacific Wheel will help you out. I had the same requirements and there are more than a few that fit the bill. Factory wheel offset is +34mm and you need something in between there and not zero.
0 offset will rub some from what I’ve heard, according to Justin +18, +25 offset wheels are supposed to be “known to fit” / function without mods.
Good luck!
melvimbe
Offset isn't the only factor though, as the width of the wheel also matters, as does the tire you're using. As stated already, the smartest thing to do is talking to the many vendors on here to let them do the math for you.
I went through @Nick@Apollo-Optics for my wheels about a month ago. Got the Black Rhino Abrams 17x8.5 w/ 0 offset and have no issues with the stock tire. Well, I did get some rubbing with the aftermarket mud flaps, but was taking those off anyway.
Trucks with the live valve shocks sit higher in the front than the ’17 MY though. keep that in mind.
Nick@Apollo-Optics
Hello,
Thanks!
Thank you for reaching out. As I mentioned before, for your 2018 truck and no modifications at all, the +25 offset of the AlphaEquipt wheels should be perfect for you.
Thank you for the tag!
