12V power
TheJoker
N. E. Massachusetts
^^^What he said^^^. Fast and easy.
It also depends on what you are doing. You could tap into the 7 pin connector if you wanted to.
I ran a 10 gauge wire from the battery (fused) to the bed in order to install bed lights and a power outlet. 156 LEDs:
H
HarleyGirl
FRF Lady
FRF Lady
Houston, Texas
I have a whipzilla led light. I had it on my hitch receiver, wired to my 4 pin. I have a chase rack now & I want to mount it there, near the cab. Nothing permanent, just something I can plug & unplug when needed.
Yukon Joe
Trafford, PA
Thirds on the direct from battery with a fuse.
You can run it down the passenger side inside the frame, or along it.
For that whip, a 5 or 10 amp fuse should be fine. But you should check with the manufacturer.
TheJoker
N. E. Massachusetts
Ok, if that's all you need it for, you could always just buy an extension. They are available at auto stores or online. A 60" 4 pin trailer plug extension should work (they come in a verity of lengths). You only need it during runs, correct? Maybe, get one longer than what you need and secure the slack. GL
Plug n play baby!
Yukon Joe
Trafford, PA
Plug n play baby!
I've done the same thing to run my whip.... that setup works great for on road and campsites. But be cautious with it offroad. I pinched mine off the first lap at TRR.
@Yukon Joe :baby: :baby:
www.runraptorrun.com
HEAVYDUTY
anyone have a video on how to do this?
---------- Post added at 07:56 PM ---------- Previous post was at 07:55 PM ----------
You wouldn't happen to have a video on how to do this?
