- Joined
- Jul 18, 2017
- Posts
- 2,963
- Reaction score
- 1,382
Sorry we've not been posting lately, we've actually been busy developing products for the new Bronco. I'm happy to report however that our 10" Lower Grill Kits for the Gen2 Raptors DO FIT the Gen3 Raptors without any modifications.
When we designed our KR Off-Road lower grill brackets last year, we designed them with plenty of adjustments for all the popular LED light bars on the market.
This kit bolts right up to your Gen2 or Gen3 Raptor.
It's available here: https://www.4x4truckleds.com/kr-off-road-lower-grill-light-bar-kit-for-2017-2020-ford-f-150-raptor/
These KR Off-Road brackets are designed to fit the 2017-2020 Ford F-150 Raptor. They allow you to mount most light bars between 6" and 12" LED your Raptor's lower grill (light bars must have mounting points on either end of the bar). Available with or without a light bar.
FEATURES
NOTE: Some light trimming is required of the plastic grill insert (the 4 grill mounting tabs will need to be trimmed off). You will no longer be able to run a front license plate in the factory location while using this kit. We recommend purchasing the SwarfWorks Front License Plate Relocation Bracket if you require a front license plate.
OPTIONAL LIGHT KITS
Add on an optional light kit for a complete solution. Each kit includes the following:
BAJA DESIGNS 10" ONX6+
At an impressive 12,450 lumens per 10” section, the brightest just got up to 50% brighter. The OnX6+™ LED light bar also integrates Baja Designs’ trademarked High Speed Spot™ reflector, the same one used by our Team Enlightened racers, to give you the guaranteed furthest projecting LED Light Bar on the planet. In addition, the OnX6+™ LED light bar adopts industry standard sizing and is now compatible with aftermarket mounting systems. A Limited Lifetime Warranty is included for the ultimate in purchase protection.
Available in 6 patterns: Racer, High Speed Spot, Driving/Combo, Wide Cornering, Driving/Combo (Amber) & Wide Cornering (Amber)
BAJA DESIGNS 10" S8
Baja Design’s latest LED light bar comes with a few new perks! Enjoy the clean aluminum frame with 6,350 lumens of pure power, low amp draw of 4.0 amps, and nearly 50,000 hours of LED life. The S8 also features upgraded reflectors, an amber backlit feature, and new scalloped housing design. A Limited Lifetime Warranty is included for the ultimate in purchase protection.
Available in 6 patterns: Spot, Driving/Combo, Wide Cornering, Work/Scene, Driving/Combo (Amber) & Wide Cornering (Amber)
RIGID INDUSTRIES 10" RADIANCE+
The new RIGID Radiance Plus light bar is the perfect solution for those who want RIGID’s legendary quality at a level everyone can attain. Featuring RIGID’s improved LED technology, the Radiance Plus light bars deliver up to 35% more raw lumens than before. The RIGID Radiance Plus bars are built with the same high-grade aluminum alloy housing as our legendary E-Series bars, but that’s where the visual similarities end. Inside, the Radiance Plus bars are feature-packed, with a black exposed circuit board, optimized forward projecting Broad Spot optics that combine the attributes of a spot and flood beam pattern. Further, the Radiance Plus bars have built-in back-lighting available in white, amber, red, blue and green. Large back-lit and recently updated RIGID branding plates further add to the unique look of the Radiance light bar. Even better, the Radiance Plus light bars now include a wiring harness and multi-trigger switch for a quick and painless installation. The RIGID Radiance Plus light bar is for the customer who wants a truly custom look that only RIGID can provide.
Available in 4 back-light colors: Amber, Blue, Red & White
RIGID INDUSTRIES 10" RADIANCE+ SR SERIES
The versatility of the RIGID Radiance lighting family just got even better with the introduction of the Radiance Plus SR-Series. RIGID’s RGB LEDs provide the user with the ability to toggle between eight available back light options with the flip of a switch: Red, Green, Blue, Light Blue, Purple, Amber, White or Rotating. The RIGID Radiance Plus SR-Series single row LED light bar is the perfect solution for those who want RIGID’s legendary quality at a level everyone can attain. Utilizing RIGID’s LED technology, the Radiance Plus light bars feature the same superior build quality as the rest of RIGID’s lighting products, providing reliable and efficient lighting on demand. The Radiance Plus SR-Series LED light bars are built with the same sleek low-profile high-grade aluminum alloy housing as the legendary SR-Series, but that’s where the visual similarities end. Inside, the Radiance SR-Series is feature-packed, with a black exposed circuit board, optimized forward projecting Broad Spot optics, prominent RIGID branding plates, and RGB LEDs with seven back light colors. The RIGID Radiance Plus SR-Series light bar is for the customer who wants a truly custom look, making it easier than ever to Own The Night.
FEATURES
- 10 Gauge #304 Stainless Steel
- Powder Coated Black Finish
- Universal application for most light bars between 6" and 12" in length
- Mounting hardware & instructions included
- Bolt-On Installation
- Lifetime Warranty
- Designed & Manufactured in the USA (Long Island, NY)
OPTIONAL LIGHT KITS
- 1 Pair of KR Off-Road Brackets
- 1 Light Bar
- Mounting Hardware
- Wiring Harness
- Installation Instructions
BAJA DESIGNS 10" S8
