1/31 squad
xxxspace
Michigan
FP said produced and on its way to get the bedliner sprayed in. Tracker is down for me.
What is your blend number? It is the big bold number right after the blend date on your window sticker? That should be the sequence number the truck hit the assemble line on the blend date.
Manners226
TN
My 1/31, 2/4 Blend date 800A now shows released to body shop for the spray-in bed liner. Hoping for delivery end of next month.
JAB2435
Georgia
This is what I got from FP this morning.
Good Morning Jeff,
Your Raptor is in production at this time. I do not show an updated completion ETA or ETA to dealer at this time.
I have seen several Raptors that were in production see the same type of delay. I am not sure what is causing that delay at the plant unfortunately since we do not have a window into plant operations here.
If you want to check back with me next week I can see if there is some movement.
xxxspace
Michigan
Good Morning Jeff,
What is your blend date and blend number?
ThankU45
MA
I just checked with FP chat and same thing - in production but they aren't able to see more than that. Asked to check back in a few days. Here's what my window sticker shows for blend info. ~2K trucks behind xxxspace if I'm interpreting this correctly?
xxxspace
Michigan
Yep, that number is the sequence number they build the truck and will reset every 10000, I think the Dearborn factory is building as of 02/04 blend now, you should see some update soon!
Here is the blend number explanation:
