ASR Kinetic Recovery Ropes Group Buy
imdubious
Broussard LA
Hey guys have talk with ASR and there intrested in a group buy for there Kinetic Recovery Ropes. There are an Econamical alternative to Bubba ropes.
Plus they will make custom lengths.
ASR's Kinetic Recovery Tow Ropes are THE tool to use when towing stuck vehicles. Utilize the kinetic energy of the tow vehicle to apply more extraction power to the stuck vehicle without cringe inducing jolts. Other tow equipment like chains or standard tow straps can transmit unnecessary, damaging impact forces to both vehicles if used with any sort of a running start. Our Double Braid Nylon material provides up to 30% elongation during use, which translates into lower impact but higher energy transfer to the stuck vehicle. It just works better in most situations than any other option out there.
•Perfectly Suited For Low Traction Situations
•Made From Extremely Durable, Shock Absorbing Double Braid Nylon
•Heavy Duty Cordura Abrasion Protection In Both Eyes And A Slider Section In Between
•Marine Grade Coating For UV and Abrasion Resistance
•Made In USA
Application Guidelines:
3/4": Suitable for use with most small off-road vehicles - MBL 19,000 LBS
7/8": Suitable for use with most mid-sized off-road vehicles - MBL 28,300 LBS
1": Suitable for use with most full-sized off-road vehicles - MBL 33,500 LBS
3/4" Shackle Specifications:
Finish - Hot Dipped Galvanized
Material - High Tensile Steel, Grade 6, Quench and Temper Heat Treated
Working Load Limit - 9,500 lbs
Min. Breaking Load - 28,500 lbs
So far this is what I have.
Imdubious 1-1/4" X 50' + 2 shackles(Pm Received)
Steele16 1-1/4" x 30'
kypatriot 1-1/4" x 30' + 2 shackles
Carson 1-1/4" x 30'
Beemerman 1-1/4" x 30' + 2 shackles(Pm Received)
MotoMute 1-1/4" x 30'
Turbo95max 1" x 30'
We would want to see a minimum total of 5 items included in the group buy. Pricing would be:
3/4" Shackle $14.00
1" x 30' - $95.00
1" x 50' - $125.00
1-1/4" x 30' - $145.00
1-1/4" x 50' - $200.00
Big Blue
Administrator
Staff member
Admin
USA
Not trying to hyjack, just want to make sure you guys know there are much more economical alternatives...
Cabela's: 30' Recovery Strap with Sewn Loops
I have this and have used it countless times.
Its 3"X30' and has a 27,000 lbs rating....and its only $49.99 with free shipping!!
keatonskidmore
Theres a big difference in recovery straps and kinetic ropes...
Sent from my SCH-I535 using Tapatalk 2
imdubious
imdubious
Broussard LA
1" x 30' - $95.00
1" x 50' - $125.00
imdubious
imdubious
Broussard LA
ok need at least 3 more.
---------- Post added at 07:39 PM ---------- Previous post was at 07:34 PM ----------
I'll update the first post to keep a list of those that are interested.
