****!!!! I know i beat you damn slow mice
Had you typed less you probably would've won.... Your post came in within <10 seconds after mine
you have smaller tires in the front that in the back going down the road in 2 wheel drive..... or you have bigger tires in the back
No. At least not in my truck. According to your picture, you're just under 2,000 RPM. 70mph as marked by the speedometer is directly on top of 2,000 mark. You're just under 2,000, so you could have snapped the picture while decelerating and it just happened to be at 70mph, yet you're coasting -- so there is why you're just under 2,000.wouldn't my RPM's be lower if my foot was off the gas and I was coasting?
Ok. Heres another hint.
I'm at 4 degrees down, but only in the front.
