Clicking from Dash (Video with Sound)
WNCHSTR96
Athens, Alabama
Here’s the procedure, scan tool is not required.
NOTICE: The ignition key must be off when replacing the actuator. Energizing the actuator before installation will cause the part to become positioned incorrectly and proper orientation will be lost. Incorrect actuator operation will result.
To install, reverse the removal procedure.
NOTE: The purpose of the module actuator position calibration is to allow the HVAC module to reinitialize and calibrate the actuator stop points. To carry out calibration, carry out the following steps.
Remove BCM fuse 46 for at least one minute.
NOTE: When the ignition switch is switched to the ON position, the HVAC module will initialize and calibrate the actuators. Calibration of the actuators will take approximately 30 seconds.
Reinstall BCM fuse 46. Turn the ignition switch to the ON position and wait 30 seconds before verifying correct mode door actuator operation.
I see it’s a different fuse than what I had found. (15 vs 46) now I need to look into it.
MurderedOutSVT
Brodozin
The ATL
Just to follow up...I lucked out and it was the one in the driver footwell. Autozone had the part in stock, so I ran up there and followed the instructions earlier in this thread, and am happy to report the clicking has gone away. Thanks to everyone who commented about the issue.
Glad it worked out good for ya!
Tinez
What’s this part called. I’m having the same issue right now. Started a couple days ago.
Thanks in advance.
Meat2022
Alabama
So did you have to do the process fordtechone said even though it was the drivers side ? I'm doing mine this weekend also.
Meat2022
Alabama
So my ac works fine it's only when it's on max ac and only blowing on the face or chest level option it clicks, if its on my face and feet and not on max ac , no noise or anything it just works.
Meat2022
Alabama
No, I just swapped the part and everything went back to normal.
For the way I understand the replacement, if you pay attention to the gear position and put the new part in with it lined up exactly like the old one it's not an issue. This is just based off a few videos ive seen so I dont know, I just dont feel like laying under the dash right now lol, my last neck surgery it just isn't fun getting in odd positions still.
