Success !!!Nice. I tried to color match my tires LOL
I got their low end headers and picked up about two MPG. Install wasn’t cheap, but you might want to get the bottom spark plugs done at the same timeSold the 3.5 Plati and got a 6.2, closer to back now. View attachment 487870
Anybody installed the stainless works headers on these? I know it sucks, but I want them and probably need someone to convince me not to.
Bozo mistake today.
Installed my faction fab resonator delete. For some reason I thought I needed to notch it to fit over the stock nipple since the oem one is a twist lock.
Now it has a small leak because it was designed to be an inch shorter than the stock one.
Win some loose some.
I’ll be putting my stock one back on and probably selling this for almost half off ($100).
someone with a welder can fix.
This^^^Or TIG back up what you did wrong?Any room to put a band clamp around it?
Bozo mistake today.
craigslist..... find a welder to do itBozo mistake today.
and this one time, with a band clamp......Any room to put a band clamp around it?
It already has a 1 inch band clamp but i can probably take it off and slap some permatex exhaust gasket maker on the spot and clamp down over it.Any room to put a band clamp around it
Where did you get the smoked markers? I got the smoked mirror sequential leds for both the front and rears and want to do the markers and grill next.Replaced the side markers and third brake light with smoked out led's. The only issue i have now is my car alarm is randomly going off. Checked the battery voltage and that's good so gonna have to hunt that down. Next up replacing the trans cooler line that just started to leak..
