2024+ Ford Raptor Gen 3 (refresh) Center Bumper Guard Plate
MandR Automotive
Fits 2024 Ford Raptor Gen 3 Refresh. This is still the Gen 3, but it is the refresh model with recent updates.
Why do I need a metal guard?​
The factory Ford Raptor Gen 3 (refresh) has a large plastric openings that don't protect your lower active ******** and coolers. We designed a metal guard that is powder coated black and has a rugged design. It replaces the factory plastic trim in your lower bumper to add some protection and even light up the night. You can add two (2) LED light pods to make your Ford Raptor Gen 3 (refresh) truly one of a kind.
  • Protects Your Ford Raptor– Protects from rocks and road debris
  • Prevents Damage to the Truck – Shields the lower bumper center opening
  • Very simple install - no cutting or drilling. Reuse factory bolts and openings. You don't need to take off the whole grille, only unclip back the sides.
DUAL COLOR LIGHT PODS
  • Main white LED light is powerful and very bright. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the in-coming traffic and also violates road safety.
  • The amber or red DRL is purely for aesthetics. It doesn’t give out much light, but more of a backglow. Something extra to make you stand out on the road.
  • You choose your backlight (amber or red)
    • 1) Amber back light that can be wired as turn signals
or
    • 2) Red backlight that can be wired as turn signals or break light
  • Driving/Flood Pattern: longer and wider beam focuses for illumination further down the trail or road as well as peripheral angles
  • Each LED light pod is attached to a metal powdercoated bracket
  • The only position of these pods is in the center as pictured
  • Metal guard is powder coated black
  • No cutting or drilling required. The kit is a complete bolt on
Ger more information about the 2024+ Ford Raptor Gen 3 (refresh) Guard Plate HEre
jk47
illinois
or
Do you have one that fits the modular bumper of the 2024?
zachery55
Rocklin, CA
I believe that center piece is the same on both modular and non modular but I am also curious. Think this looks cleaner overall versus the current set up from factory. I’m torn on the pod lights tho. Not so much just brand but the style. Feel like a light bar behind that grille piece would look better, or maybe some bigger pods. They look fairly factory but almost too small for that area of that makes sense. Seems like you could almost get 4 pods there instead of two. I’m interested in more details for sure on this.
jk47
illinois
They are different and it seems no one has done anything for the modular bumper yet… SPV has a bracket system you can put a 10 inch light on but that’s it. I want to take the active shutters out but don’t want a direct path at the new intercooler either. 3rd world problems….
chi_weezy
Sacramento, Ca
Hmm. I measured it on my truck, could fit a 16” light bar, MAYBE even 18” max. 10” is pretty small. That’s what she said, so she dumped me but that’s another story.
zachery55
Rocklin, CA
Naw that center piece has to be the same. I have the modular bumper too and that shit looks the same as this one lol.
But Ya hear ya there on the rest of it. I saw the spv awhile ago when it came out but it modified the bumpers center section. If that bracket and light could fit behind this cover then that would be pretty legit.
