OEM Fog Replacements for Raptor, 35, 37 & R - Available NOW - Rigid Pro Series SR-M, Diode Dynamics SSC2 & Baja Designs & More
Specialtyperformanceparts
I had a set of Baja Designs lights laying around from my Gen 2 so I wound up throwing them on my new truck using the SPV mount bracket and some harnesses.
I‘ll admit I was skeptical about the included templates but they are actually 100% spot on. It’s so much easier having the lights exactly where they should be and then just bolting up the bracket instead of adjusting while on the truck and trying to get everything even and uniform on both sides.
I used some harnesses from SPV to attach the BD lights to the OEM wiring. I used 2 pairs of OEM connector to weather pack connectors and a pair of y splits. I set it up so the OEM fog switch controls the pair of S2 sport wide and the pair of Squadron Pro mixed driving and aux 1 controls the pair of Squadron Pro Spots.
Fyi a pair of Squadron Pros and S2 Sports are a little over 8 amps, the OEM switch is supposed to be a 10 amp circuit. So far I haven't had a problem with the fuse blowing.
View attachment 464752View attachment 464753
Looks great! I'm glad the install went smoothly, and the template was helpful.
Please let us know if we can ever assist with anything else!
Thank you for allowing us to earn your business!
-Sidney @ SPV Parts
(317) 934-6778
info@spvparts.com
