Eibach Springs Available and In Stock for your Gen 3 Raptor Here at Apollo Optics!
JayRods
Manteca Ca
I’ve been floating around here a bit. That’s one of the best mods I’ve seen on this forum. Clean fab and looks factory. DB should be paying attention to this hopefully.
Thanks, I tried to post a video of it working, but I guess it to big to attach it.
Hambone
Atlanta
Wow! Good job. If you don’t mind, what did you pay for the Eibach spring installation? You can dm me if you’d like. Thanks!
KODIAK
I ordered a set of rear springs today 1.5". I'm hauling around 740 lbs of tools and stuff for work in the rear and it sagging a bit. Hoping the 1.5" will level me out again.
How’d they work out?
Nick@ApolloOffroad
Nick@ApolloOffroad
TXRaptor37
georgetown. tx
Man, that looks killer! Any rubbing issues with the little bit of extra offset?
Zero rub after the 1” springs. Had a slight rub on the carpet liner on the back of front wheel well with stock suspension. Had that trimmed a tiny bit while getting the springs installed, but I think they would have cleared anyways with the 1” added.
I def would recommend not doing a negative offset as the +1 have plenty of poke IMO. If these wheels came in a +10 to +20 I would have likely opted for that.
Here are some pics of the 20x9 +1 offset wheels if anyone considering new wheels to help see what it looks like. IMG_1636.jpegIMG_1635.jpegIMG_1639.jpegIMG_1640.jpeg
JayRods
Manteca Ca
This is my 2023 with Geiser Spings and 740lbs of tools and parts in the back. Looks and rides amazing.
Before and after spring install.
