Hey guys!
For years on the Gen 2 Raptor, the Eibach springs have been our go-to for raising the front of the truck and getting the improved looks that you're after with a compliant ride to back it up and we're now proud to offer them for both the front and rear of your Gen 3 Raptor, too!
And right now, ALL springs are options are IN STOCK!
For starters, there are two height options available: 1" Front lift only or 2.2" Front Lift and 1.5" Rear Lift.
Both of these kits will work on both the factory 35" trucks and the 37" Performance Package trucks as well, and the part numbers are the same.
For the front, if you're just looking to add the 1" of height to level it out, you'll want this kit here: Eibach 21-23 Ford F-150 Raptor Pro-Lift-Kit Front Springs 1 Inch Front Lift E30-35-060-01-20
If you're wanting to upgrade both the front and rear to get a "mini-lift," then you'll want to add this kit here: Eibach Pro-Kit for 21-23 Ford F-150/Raptor (2.2 Inch Front Lift / 1.5 Inch Rear Lift) E30-35-060-02-22
And of course, we have the front 2.2" springs and the rear 1.5" springs available as separate options, if you need to get your setup dialed in to your specific needs.
Front 2.2" Springs: Eibach 21-23 Ford F-150 Raptor Pro-Lift-Kit Front Springs 2.2 Inch Front Lift E30-35-060-02-20
Rear 1.5" Springs: Eibach 21-23 Ford F-150 Raptor Pro-Lift Kit 1.5 Inch Rear Springs E30-35-060-02-02
New Update as of October 26th, Eibach now has their HD Rear Spring Option available!
The HD rear spring option works on both the Raptor and Raptor R.
For the Raptor, it will provide the following lift heights:
Raptor: +2.3-0.6" lift from 0-500lb load
Raptor R: +1.9-0.5” lift from 0-500lb load
Here is the link to the HD Rear Springs: Eibach HD Rear Springs for Ford Raptor & Raptor R at Apollo Optics
Lastly, if you need to customize your setup to your needs, we can also mix and match the Eibach springs with front collars, rear spacers, or even other brands of springs like Geiser, which are on the site as well.
As always, feel free to send me a PM directly if we can help with anything at all to dial in your build. And if you're looking for wheel and tires to go with your new suspension, we're happy to help there as well!
Thanks!
Nick
Thanks!
Nick
