NJ2020
Did you have the dealer reset the bms?Replaced mine with a DieHard Platinum AGM Battery: H7 Group Size, 850 CCA, 1000 CA, 140 Min Reserve Capacity, For High Electrical Demands.
No issues now !
No issues now !
30m round trip M-F
So, the vehicle sat for two weeks until November 1st when I returned from overseas. First time I received message was when I was away, since returning it been back and forth to work, lunch, maybe weekend errands. Last couple of weeks not much weekend stuff, and its been colder. Messages started again. Maybe it's telling me I need a 6+ hour drive/weekend up to Moab, Utah!!Something does sound fishy here. But It’s not a 30 minute drive.
It’s two 15 mile drives with 8-10 hours in the parking lot, with maybe even a short hop for lunch.
The drive starts with a low battery. Temp is cold enough for hvac fan and heated seats to be running. It’s most likely dark so the lights are on. Part of the drive is Highway and part stop and go.
This likely isn’t enough to top up the battery.
In my mechanical opinion (and I'm not an expert but turn my own wrenches) the best way to test a battery is:Ask FTO, that 14.5v might be with the alternator charging at 14.5v. Use a multimeter to check battery charge after the vehicle sits overnight, WITH THE ENGINE OFF (not running).
You sure could have a parasitic gremlin. You can test this with a multimeter as well. Either google search how to track down the parasitic draw or maybe FTO will give a simplified explanation.
Those 20 mile commuting drives might not be replacing all of the charge deficit. Giving it a full charge with a high quality battery charger once a week might solve your issue.
There was a very informative thread on one of the Ford forums from a mechanic who’s F150 suffered from low charge due to short commutes. Maybe someone remembers where that is?
I use this Victron unit:
I really like the X2 power batts. I go by how much does the battery weigh when choosing a new one. Those X2’s are heavy.
FWIW I replaced the battery in my 2018 Raptor with a factory battery because it was a bit heavier than the X2Power.
I think there was a post on the weights of X2Power/Motorcraft/Odyssey Red Top recently. All three were roughly the same.
Good luck with solving your drain issue and make sure to get back to us with the solution. This helps us all.
I’m happy to see that this forum is morphing towards supplying useful information as our vehicles age.
I’m active in three other forums that have amazing communities of helpful members. One is the solar forum sponsored by Arizona Wind and Sun, the other two are an OBS Ford forum and the Alfa Romeo BB.
I’m looking forward to FRF’s continued growth.
Thanks moderators for the forum!
OP. This does sound like a run down battery. If it was me I would hook the Victron charger up to the battery and give it a complete charge.So, the vehicle sat for two weeks until November 1st when I returned from overseas. First time I received message was when I was away, since returning it been back and forth to work, lunch, maybe weekend errands. Last couple of weeks not much weekend stuff, and its been colder. Messages started again. Maybe it's telling me I need a 6+ hour drive/weekend up to Moab, Utah!!![]()
No. I reset it my self.Did you have the dealer reset the bms?
YesCurious, were you having similar issue before changing out battery?
