Cody Templeton
Installed the Cravenspeed dead pedal last night. Issue I ran into is that I tightened the top nut too much and broke the stud off the firewall. I decided to just go one better and drill the stud out and nut and bolt the top mount with an M8 bolt rather than the M6 bolt to make it even sturdier. I have some Grade 10 hardware laying around that fit perfect and it was easy to drill the hole in the firewall and install it. Also, instead of using the self tapping screws that came with the kit I used black self tapping screws that I had so they blend into the pedal. Extremely sturdy with zero flex, and doesn't look out of place.
