Top Perch Mod- Alignment
BIRDMAN
Birdministrator
Boston
I got my alignment done today after adjusting my Shox to the top perch, I thought this would be helpful for those looking to do the same mod. Apparently the only adjustment we can make is for the toe, which was way off and causing my steering wheel to sit at almost 1 o'clock while going straight. The negative camber is still within range and cannot be adjusted.
I was also experiencing some squirrely-ness over small bumps causing my front end to skip from side to side. I attributed this to the firmer ride up front but after the toe adjustment that characteristic is completely gone. The ride now is very favorable over stock.
2010 Shelby
West Virginia
So did you install the camber adjustment kits or were they able to do this with all of the stock components?
96,856
60,809
hazardsyd
