SDHQ Bump Stop Mount Install
firematt422
Kansas City
Just threw these on today. Took about an hour. They replace the part that juts out from the stock rear suspension block if you have a progressive leaf pack so the jounce bumper doesn't bottom out.
Remove the U-Bolts from the leaf spring.
The mounts are marked "Driver" and "Passenger" because each has a slight rake in opposing directions.
Put on accordingly after removing the stock shim that holds the U-bolts in place.
The SDHQ piece fits right over the 2 bolts holding the leaf pack together.
Replace the U-bolts on the leaf springs. Don't tighten all the way at once. Try to tighten equally between all 4 nuts so you don't end up crooked. I used red Loctite, not sure it's necessary, but I like it.
Then put the supplied U-bolt up from the underside around the axle into the bump stop mount and screw on the nuts.
Also... for ***** and giggles, anyone with stock suspension have a measurement from their jounce bumper to the ear on the suspension block? Mine is now at about 6-6 1/4" of up-travel. (Sorry, not very good pic here)
---------- Post added at 03:47 PM ---------- Previous post was at 03:44 PM ----------
Also... before anyone says anything, I shot some Rustoleum on my springs and diff cover today too. Missouri salt is a killer.
firematt422
firematt422
Kansas City
Yeah, no problems at all. Thanks for throwing in the extra stickers and the Mint 400 DVD also. Awesome documentary.
