*READ BEFORE POSTING* Suspension FAQ
Status
Not open for further replies.
KaiserM715
Kaiser Söze
These questions seem to come up frequently, so here is a post with the answers. Each link goes directly to a relevant post so that you don't have to look through a whole thread. This is a work in progress.
Perch mod how-tos:
http://www.fordraptorforum.com/f9/perch-mod-shocks-truck-14082/
http://www.fordraptorforum.com/f9/how-adjust-fox-shock-perch-height-level-front-6969/
Perch Mod before and after pics:
http://www.fordraptorforum.com/f9/perch-mod-discussion-5217/index68.html#post718953
http://www.fordraptorforum.com/f9/mid-perch-before-after-pics-20827/
Perch Mod vs Leveling Kits:
http://www.fordraptorforum.com/f9/perch-mod-vs-leveling-kit-discussion-19953/
http://www.fordraptorforum.com/f5/why-spacers-bad-idea-lots-cv-axle-innards-pics-11645/
http://www.fordraptorforum.com/f9/leveling-kit-spring-spacer-lift-block-no-nos-20559/
Perch mod TSB:
http://www.fordraptorforum.com/f183...ch-modifications-effective-2-24-2014-a-32822/
How To: Geiser Brothers Progressive Coil Installation
http://www.fordraptorforum.com/f170/geiser-brothers-progressive-coil-installation-47873/
Basic alignment info:
http://www.fordraptorforum.com/f9/your-raptor-its-alignment-539/
pirate air's alignment specs:
http://www.fordraptorforum.com/f9/your-raptor-its-alignment-539/index5.html#post176634
http://www.fordraptorforum.com/f9/your-raptor-its-alignment-539/index20.html#post620727
Camber / Caster kits:
-SPC
http://www.fordraptorforum.com/f9/your-raptor-its-alignment-539/index7.html#post203146
http://www.fordraptorforum.com/f9/camber-caster-kit-specialty-products-company-p-n-86250-a-27915/
-Ford
http://www.fordraptorforum.com/f9/your-raptor-its-alignment-539/index6.html#post201629
Stage 2 Install:
http://www.fordraptorforum.com/f9/rpgs-stage-2-kit-rear-frame-support-fox-air-bumps-10553/
Stage 3 Install:
http://www.fordraptorforum.com/f9/rpg-stage-3-rear-suspension-installation-47796/
Knuckle part numbers:
http://www.fordraptorforum.com/f9/oem-ford-raptor-steering-knuckle-part-s-34798/
Knuckle Gusset information:
http://www.fordraptorforum.com/f170/diy-sdhq-knuckle-gusset-writup-39460/
Leaf Spring Removal and Installation:
http://www.fordraptorforum.com/f9/how-remove-replace-raptor-leaf-springs-6970/
Status
95,505
59,113
SK Raptor R
