Turf Tamer
Recently had the pleasure of doing business with the Outlaw guys and had them fab me a set of custom bed braces.
After the RPG SEMA run I noticed my bed sides had begun to spread near the top rear leaving a uneven gap from top to bottom while the tailgate was closed. This gap also prevented the rear panel of my Bak F1 from catching the rails and locking in place which caused it to bounce up and down while on the trails.
Gap caused by the bed spread
![3a691bfe0728ce82e5534b3628307be8.jpg 3a691bfe0728ce82e5534b3628307be8.jpg](https://www.fordraptorforum.com/data/attachments/192/192937-cd9d14ed8fb206ba41b7c8d49dbb0723.jpg)
![c3c5f25554da00ea457e482b95d439f6.jpg c3c5f25554da00ea457e482b95d439f6.jpg](https://www.fordraptorforum.com/data/attachments/192/192938-93acb5cda4fe039811872f08c31f03a3.jpg)
![92c05ed98b80c4bd63d8c04ac5254c3d.jpg 92c05ed98b80c4bd63d8c04ac5254c3d.jpg](https://www.fordraptorforum.com/data/attachments/192/192939-10089d8e61cb9bd0555a26cc6b827ad8.jpg)
I brought the issue to light after the run and found it was a semi common issue. I also discovered a product to correct and prevent this was not available. I made a temporary setup to fix my alignment issues using a ratchet strap and some I-bolts to hold me over until a permanent solution was found.
Temp fix, works well but is unpractical if you use the bed regularly.
Spoke with Conner, told him what I wanted and this is what they came up with.
![22ea397debf547508945e2565837d321.jpg 22ea397debf547508945e2565837d321.jpg](https://www.fordraptorforum.com/data/attachments/192/192941-9c178ca5b11d31dd7b25262d7bd265dc.jpg)
![803928d527dcfc70ba519a1be8eb4be7.jpg 803928d527dcfc70ba519a1be8eb4be7.jpg](https://www.fordraptorforum.com/data/attachments/192/192942-dad8d556274ce8b9d69cd623836c3893.jpg)
![4c35b27852f10f6ee51abcd93341ab2d.jpg 4c35b27852f10f6ee51abcd93341ab2d.jpg](https://www.fordraptorforum.com/data/attachments/192/192943-16455658a3250cceea8bf00f9c3e510c.jpg)
![dba4976187e8ed50d8e56265fd4c64fb.jpg dba4976187e8ed50d8e56265fd4c64fb.jpg](https://www.fordraptorforum.com/data/attachments/192/192944-1341452e186268cc1008005c3e1b89c4.jpg)
![f65546e25789b75a2a5f4ef59410c8cc.jpg f65546e25789b75a2a5f4ef59410c8cc.jpg](https://www.fordraptorforum.com/data/attachments/192/192945-a78dcd058a916afeef2bd1f312fd22f0.jpg)
Install was done at Outlaw, it took about 2 hours, but this included time to fab the backing plates. This was also a one off item so it takes some time. My existing setup came in handy as it allowed us to pull the sides in and tighten the heims up. We actually had to pull the bed rails in farther than we wanted and tighten up the heims so that when we released the strap bed would settle in the desired location. This was not a issue with the brace, but was due to the thin walls of the bed deforming and bending.
A week after the initial instal I made a bigger set of backing plates that helped correct the bending/deforming issues.
old backing plate top new on bottom.
![ee4ff888e18504faf4cc9e75021c1b40_zps8cd622cc.jpg ee4ff888e18504faf4cc9e75021c1b40_zps8cd622cc.jpg](https://www.fordraptorforum.com/data/attachments/192/192947-eb4eab3436b4f2c77ffe96abd4c51c02.jpg)
Overall I am very happy with the product as a whole and the service I received. I have no idea if this will go into production, but if it does I would recommend the rod be made out of a hex or square bar to allow the use of a wrench to tighten the brace (mine is hands only, but I have the strap and I-bolt setup to compensate) and make the backing plate larger like the one I made.
I will update this thread in the future once I get some dirt miles on this setup.
Thanks again Outlaw, Hope this helps out those with similar issues.
![8ead65db57aefec3cd82c607ee202b19.jpg 8ead65db57aefec3cd82c607ee202b19.jpg](https://www.fordraptorforum.com/data/attachments/192/192940-8b8a53e858e70dd5b87de34e8925e8c1.jpg)
![227b669004de8b10b6c0a1c3ee48d3b0_zps03de3881.jpg 227b669004de8b10b6c0a1c3ee48d3b0_zps03de3881.jpg](https://www.fordraptorforum.com/data/attachments/192/192946-763c956ab57f5824b119573342831e09.jpg)
