damn Fred thats bright. looks good
Thanks...I went with 5w...I think they are bright as well...I didn't realize until my wife snapped some pics...how much light they throw...
Here are the Pics of
1) Reverse Lights: 2pcs T15/T10 Wedge CREE Q5 Emitter 5W Led Reverse Back up Lights 921 912 906 #04 ( 150978252514 )
Plate Lights: 2WLED-xHP5: 194 LED Bulb - 5 SMD LED Wide Angle Wedge Base WLED-WHP5: Natural White
Where did you get the leds below? If you were trying to post links, they do not work.
If you copy and paste the info. In eBay and superbright.com you should get the lights...
I tried that and a few came up. Do they all fit? None were an exact match.
They all should work...the only concern I would have is if the bulb is to large for the housing..
Has anyone tried these led bulbs replacements for the 921 backup bulbs:
If so, are they noticeably brighter than the factory incandescent bulbs?
Try This:
Plate Light: 194 LED Bulb - 5 SMD LED Wide Angle Wedge Base | Miniature Wedge Base LEDs | LED Car Bulbs | Super Bright LEDs
Reverse Light: 2pcs T15 T10 Wedge CREE Q5 Emitter 5W LED Reverse Back Up Lights 921 912 906 04 | eBay
Fred
---------- Post added at 11:05 PM ---------- Previous post was at 10:59 PM ----------
I got the ones that were 5w and around $20...top row if that helps...
Just placed an order for these reverse lights.
