ok to start off this little write up... i went to lowe's and picked up a bracket about 6' long, it was flat when i started so i bent it into shape which was easy all i did was use a butane torch to heat it up then used a vise to bend them.
so after a few coats of paint i started taking the bed rails off pretty easy step there ... and man was there a ton of dirt under them too haha.next i lined up the brackets to the spot i wanted them in. then laid down a piece of painters tape to mark the holes to drill.
after i drilled the holes i attached the bracket with some hardware and self locking nuts with lock washers.
once the brackets were on then it was time to put the lights and and make sure they were lined up with the bed rails as best i could haha at least the brackets were straight in line with the bed rails!
next came the real fun! wiring these puppies up.. since i already had a pair of duallys in the rear ADD bumper i was gonna run the wires and tie into the wire harness for these.. now each pair of duallys only pulls 5 amps and since my rear lights were on the #3 aux switch that has the 15amp fuse i was safe to put another set of duallys on that switch and still have 5 amps left over ( math: 2 duallys= 5amps so 4 duallys=10 amps
i ran the wires down the inside the bed in one of the holes so it doesnt get pinched between the bed and cab!
next i ran it along the bottom side of the bed, between the bed and the frame.then to the driver side of the bed where i had my other lights ran up to the engine bay.
after a quick splicing into the wire harness i was done with wiring them up and i lined up the bed caps and marked where i needed to cut the cap with my dremal.
now here is some ****** day time pics ill post up some night shots in about an hour or so when it gets dark!
hope you guys like my cheap and quick (2 hours even with taking pics lol) bed rail bracket write up any and all criticism is welcome fellas! ENJOY!
