Humvee21
- Joined
- Aug 17, 2011
- Posts
- 4,848
- Reaction score
- 538
This will be my guide/review on the 894 bulb conversion to 921 for our reverse lights. I originally got this idea from a Honda Element forum (yeah... go figure). Anyway, the results seemed impressive considering that the stock 921 bulb is only a whopping 18 watts, while these 894 (fog lights) are 38 watts.
I know what some of you are thinking. You're thinking, shit that's gonna melt my housing or blow a fuse. Well, these Element guys have been running them for months with no problems. Some even had the balls to go to 50 watts, but I read 1 guy blew a fuse so I wasn't gonna take the risk. Plus, I figured that our Ford would be at least the same quality as the Honda if not better.
Here is the guide to do it:
Backup Light Bulbs
Here are some results on a Honda Civic:
DIY: Brighter Reverse Lights - 8th Generation Honda Civic Forum
Honda Element 894 conversion to 921 discussion/results:
need a reverse bulb replacement - Honda Element Owners Club Forum
I promised some photos. And I had a great idea of going to this really dark park nearby, but apparently they had parking lot lights installed recently..
Or else it'd be the perfect spot to get you guys some pictures.
These are the bulbs I purchased, but any 894 bulb will work.
Philips 894 Standard Driving Light Bulb, Pack of 1 : Amazon.com : Automotive
My results:
I only switched out one bulb so far, since I wasn't sure how this was gonna turn out. The install is super simple. I actually didn't even bother cutting the bulb housing, and I just took the easy route by cutting the 2 metal prongs as low as i could get them. Then, I bent the contacts as said in the guide (I'm not sure this is necessary). Finally, jam the bulb in without breaking it...
In broad daylight, I immediately noticed an improvement. I could visually see the difference between both lights. I did feel that the housing with the 894 bulb was slightly warmer, but unless you're reversing for minutes... I wouldn't worry about it.
At night (with parking lot lamps), I did notice a slight difference. I think most of the light was drowned out by the parking lot lamps, but I am being hopeful. I did not notice much difference when looking in my mirrors, while backing up. Nor did I notice much difference in the reverse camera. But again, these results were in a somewhat lit parking lot (i tried the dimmest spot).
My conclusion for now is that these lights are only marginally brighter. Hardly enough to justify the effort required. I can also conclude that if you're concerned with melting/blowing a fuse, you should relieve any worries of that. It seems to me that the F150's reverse light reflectors just suck in general. However, give me some time and I will be able to go back home to really test these lights in the dark.
Pictures:
This is the only picture that was actually worth taking. This was taken by my phone. I do not have a real camera with me, so I do apologize about that. I will let you guys decide which side has the 38 watt bulb and which has the 18 watt.
TO BE CONTINUED...
Please note that I do not take any responsibility for any damages this modification may do to you or your vehicle. Proceed at your own risk. This is simply my own testing. Take this information for whatever it's worth.
--------------------------------------------------------------UPDATE 2/10/2013 12:49AM EST-----------------------------------------
Finally went home tonight. Got some comparison pictures for you guys. After driving with it for about a week and a half, I must say the light output is great!
Still, no issues with melting/overloading wires or anything of the sort.
I have set up comparison pictures side by side comparing the 38 watt bulb (passenger side) vs stock (driver side) vs fully lit environment (just so you guys can see what you would actually see in the daytime). Captions describing each photo will be below the photo that is being described.
I set up two chairs to give a little point of reference. The chairs are measured to be 15 feet behind the rear bumper. As you can see, the light on the left (the 38 watt) produces a much brighter beam of light, which projects a stream of light across the entire left wall. Using the center of both chairs as the midpoint, you see that the light on the right (the stock bulb) does not project a stream of light on the wall.
Driver's side perspective
Passenger's side perspective
Direct shot
This is about 6 feet away from a small retaining wall. You can easily see where the projection of the 38 watt bulb stops and where the stock bulb is super dim. Notice the ground is lit up more on the passenger side than the driver's side as well.
Passenger's side perspective in front of retaining wall.
You can even see that very bright beam of the 38 watt on the backup camera.
Direct shot outside
I think this mod is a great one. I have tried LED bulbs and they are actually even WORSE than the stock bulbs. Unfortunately, there is not much you can do with the stock reverse light reflectors. This is, IMO, the best option if you're looking for a brighter reverse light without having to mount some fog lights underneath the bumper. Also, I said that the housing felt warmer with the 38 watt vs the stockers, but I had them on for about 2-3 minutes to take pictures and I felt no significant difference between the two in temperature.
The only bad thing about this mod is the part where you have to remove the 38 watt bulb from its plug. I wanted to replace my driver side today after I collected all these pictures for you guys, but I was too rough with the 2 metal prongs and 1 of them snapped off. Be careful with the bulbs since they are very fragile, the prongs too. I hope this helps you all that are looking for brighter reverse lights. let me know if you have any questions
Backup Light Bulbs
My results:
Pictures:
TO BE CONTINUED...
Direct shot
Direct shot outside
