RaptorScrew
Ok, so I'm reading a couple threads on here and they're talking about the PowerTank over a normal compressor...
My question is this:
Although I won't use it to top off my tires very often, does it have the ability to blow up inflatable pools (small whale kiddie pools) without a problem?
I currently have a small ProForce Powermate 2 gal compressor that I use to fill up these pools and use for my nail gun etc.
(mines quite a bit older but you get the idea)
It takes more than 20 minutes to fill the pool because I'm out of air in about 30 - 45 seconds. Then I have to wait for the psi to build back up before continuing. Max PSI on this little thing is about 80...
I need more capacity but am not sure of spending the money to get a larger compressor plus I like the portability of the small one and that is why the PowerTank caught my attention.
Would a PowerTank service my needs better and QUICKER? Can it be controlled well enough as to not blow up the pool to quickly?
Thoughts?
Thoughts?
