Start up noise with video attached
03Cobraraptor
2013 Ford Raptor 25,000 miles
Cold startup
Outside temps 70
Is this normal Lifter noise on start up?
Also at 07 seconds there's a louder thud-like noise that occurs...any ideas?
Thank you gents
weimer
VA
Mine does the same thing. The thud is the compressor turning on.
SchultzLD
AZ
At work so can't watch the vid, but like the above said... sounds just like mine; a few seconds for the oil to get moving, then the compressor kicking in.
Dane
Littleton, CO
Vid doesn't work for me. But I'm curious as to what the noise is. I've had a couple weird ones, some explained, one not.
Riddick
Can't see the vid, but I'm assuming the lifter knock goes away after a few seconds. What oil filter are you using? I had the same thing. Installed headers and changed oil at the same time with a Mobile One filter. Thought I had a header leak and spent hours retightening bolts. After some research, the stock Motorcraft oil filter doesn't allow leak down causing the lifters to be dry on cold starts. Goes away after oil pressure comes up.
