Sasquatch77
Banned
- Joined
- Feb 25, 2016
- Posts
- 825
- Reaction score
- 164
I am finding that this crimped fitting on the lower front passenger side is a common leak point. Mine is definitely blowing out fluid from the fitting / rubber hose connection. I am finding that even the replacement lines still don't fix the problem. With that said, curious about a possible fix. If I cleaned everything up, I was thinking of spraying expanding foam in the hose/crimped fitting area. That stuff seals and sticks to everything - thought it might be worth a try.
