Well a few day ago I spent the day cleaning my truck and decided to remove the door sills for better access of cleaning the carpet of built up dirt and grime. After removing the sills I noticed that there was water laying in the channel where the electrical wires run. I also noticed Crystallized salt build up from the winter. If you notice on the picture with the bottom of the truck sill exposed it shows yellow rubber like washer that must be used to stop the water from under the truck from coming in. Apparently they're NOT doing there job and allowing all this salt water from the winter to come in from under the truck and settle in the channel. Now I'm sure this is going to lead to all kinds of RUST to start forming so my idea I THINK is to maybe seal all the clips from the bottom of the truck with some kind of silicone.
What are your thoughts and suggestions on preventing this?
Yellow washers for sealing.
showing finger from under truck
Channel exposed
Red arrows indicating level line of crystallized salt
Channel exposed
