O2 sensor spacers
Hole Shot
Raeford, Nc.
I have just learned about a new solution for that pesky cel light. The gang a Svc recommended a o2 sensor spacer when you have issues with the cel due to long tube headers and high flow cats. For the price I've Seen they are a cheap remedy for the problem, and pass a emissions inspection. I was wondering if anyone has used these with success?
Hole Shot
Hole Shot
Raeford, Nc.
You still having problems? There like $14. Sounds like a cheap fix!!!
Mach1mike
Chicago il
I have used them. I put the stock tune back the spacers and new o2 sensor to pass emissions. Took them off and put my old o2 in so they don't get weathered. I'll do it again at next emission test.
NickPic83
Rockland County NY
many of used this method with success. there are some good write ups online too. the key is 2 get 2 sets of the antifoulers(spacers). drill 2 out large enough for the o2 sensor to fit thru. thats what the 02 will screw in, then screw that into the undrilled antifouler. then screw that into the ****.
NickPic83
Rockland County NY
MTF
Celebration, Florida
For $50, it's not that bad, if you want to keep the rear O2s on in a custom Tune.
Good way to help keep the motor safe. IHMO
It sounds like SVC would recommend that after reading their posts.
MTF
I don't think Simulators will work on the new 2010 1/2 and up PCMs.
The rear O2 are monitored quite differently.
But please prove me wrong for everyone's benefit.
The one that NickPic83 put up looks intriguing!
