No HEAT drivers side!
IRONMAN
Well-Known Member
MICHIGAN
Getting cold here lately so I decided to turn on the heat in my truck.
After driving for about 10 minutes I'm thinking to my self "Boy am I freezing my nuts off...WTF", come to find out that there's heat on the passenger side but none on my side.
GREAT this is all I need. Tried adjust the temp control all sorts of ways and nothing. Turned truck off then back on still jack.
Has this happened to anyone yet?
Started reading on another forum and some guys were having troubles with the blender motor going bad and the WHOLE dash needs to be removed.:snoopfacepalm:
This is the last thing I need is Ford techs tearing apart my dash. The last time they took something apart shit was put back together half ass.
Also...
Does extented warrenty cover this by chance?
Only 44,800 miles on it so far.
Any ideas from you guys would be greatly appreciated.
Also fuses are good.
Baldwin09
Thornton CO
From what I understand yes the dash needs ripped apart haven't had issues like this yet but it did happen in my stepdads f350 if I can remember correctly and was covered.
Hocker52
League City, TX
Mine did that when I first got it. It was a bad actuator in the dash they had to pull the dash to replace it. Not sure about the extended warranty though.
BIRDMAN
Birdministrator
Boston
Also...
That happened to me, remember?
Sent from my thumbs using Tapatalk 2
BIRDMAN
Birdministrator
Boston
It was the blend door actuator yes. They tore out my entire dash..wasn't terrible but mistakes were made.
pirate air
will plunder your booty
All sounds about right and I believe extended will cover it.
