Bulletnjm
Stupid question but, the wheel has to be off the truck to measure right?
Thanks for the response Vince, I'll have to see what I can do - I think it looks wrong with these stock center caps. Am tempted on the rim I *****'d to sand down the powdercoat in the center bore section to see what that takes and how they fit then. I'll figure something out and let you know either way.not really caps are cut in large runs and current run is almost here, when we designed the caps they were reduced to accommodate their powder coating to fit perfect in wheel, method wheels aren't powder coated in the hole and if it is its very minimal.
if and when they're is another run, not sure what machinist would charge me to do a one off set but only way to accommodate your newly coated wheels would be for you measure the diameter opening and make some accommodations from there.
