Hands down the best OEM pocket fog kit available
rms8
The pocket fog kit designed and sold by www.fordraptorlights.com is absolutely the slickest, OEM looking fog kit available. The attention to detail is remarkable. The kit comes with a top notch wiring harness which fits perfectly! Took less than 2hrs to install everything and that includes cleanup/putting tools away. Highly, HIGHLY recommended for those with factory bumpers. I'm so glad I waited before purchasing something to fill those holes.
Jayrod
FL
Looks killer I should have mine today or tomorrow. Tell me about the wiring harness, is it plug and play is there actual splicing and all that involved?
ChevTillNow
PNW WA
Yes it sure does look nice and clean! But how about taking and posting some night shots from inside and outside of the cab without headlights.
Which lights did you go with by the way?
Look forward to seeing the night light up, thanks in advance
marsh1
Received mine yesterday and as OP said the quality of parts is top notch. Will be installing this weekend. Will post pics but thing to remember is you tailor the light output you want when you select the cubes. I went with Rigid Cubes because I wanted the Amber backlighting. There were brighter options.
