I need to put my order in and I'm stuck between two models.
Can I get some votes on which one you guys prefer:
1: Stealth R:
![2017-ford-raptor-winch-front-bumper.jpg 2017-ford-raptor-winch-front-bumper.jpg](https://www.fordraptorforum.com/data/attachments/264/264700-a1419d4813b41cdd41914cd08572f412.jpg)
2: Venom R:
![2017-ford-raptor-winch-front-bumper.jpg 2017-ford-raptor-winch-front-bumper.jpg](https://www.fordraptorforum.com/data/attachments/264/264701-3d6d80f6954c8ef17d4338a504b24c75.jpg)
Flush comparo:
1. Stealth R: (without winch)
![raptor-custom-front-bumper.jpg raptor-custom-front-bumper.jpg](https://www.fordraptorforum.com/data/attachments/264/264702-8ce99948d70008b3af13cbad7eb723ae.jpg)
2. Venom R (with upper lamp and winch)
![2017-ford-raptor-winch-front-bumper.jpg 2017-ford-raptor-winch-front-bumper.jpg](https://www.fordraptorforum.com/data/attachments/264/264703-859cdf606949e0cddc0e9e7cef74f8dc.jpg)
![ford-raptor-front-bumper.jpg ford-raptor-front-bumper.jpg](https://www.fordraptorforum.com/data/attachments/264/264704-3617c7092c2bd53c867cbd6e55ba394a.jpg)
1. Stealth R: Has a protected light bar with the metal bar above it. It has room behind the ADD logo for a small hidden light bar (with associated light loss) and for the two spots on the side. If I purchased this one I would get the hidden light bar and spots in amber in a fog light pattern and the main light bar as a long distance spot. This bumper appears to give a slightly better approach angle than the other one, but it also protrudes out a lot further.
2. Venom R: This bumper doesn't allow for side facing spot lamps. I would use the lower bar in a sweeping flood light pattern and the upper as a long distance spot. It's very nice but it might actually be overkill with insane amount of lumens going out. The upper bar isn't as well protected and may have a slightly worse approach angle than the other. The biggest upside of this one is that it is a lot more flush to the bumper. The biggest downside is that the upper lamp seems a bit like an afterthought.
So which one?
Thanks
1: Stealth R:
2: Venom R:
Flush comparo:
So which one?
Thanks
