DIY Bed mods to keep off road supplies handy
J.Bodolay
Bed Liner + Fuel/Water storage + Pioneer gear.
This is the my '17 repeat of the bed mod I did on my '11 Raptor. 6+ years later, everything has held up great. Can't count how many times I've been able to get myself or someone else out of a jam by keeping a few helpful tools/supplies handy, secure, and out of the way in the truck bed.
Bill of Materials:
BED LINER (4hrs)
Raptor Bed Liner Kit.
Masking/Sanding Materials.
Application Gun
FUEL/WATER STORAGE (30 min)
Rotopax twin mount and containers
Drill, 3/16 bit, 3/16 x 3/8 aluminum pop rivets
PIONEER GEAR (1 hour)
Shovel, Pick, Axe of your choosing
Black spray paint
Quick Fist mounts (3 sets)
Drill, 3/16 bit, 3/16 x 1/2 aluminum pop rivets
hewster
Virginia
Bill of Materials:
BED LINER (4hrs)
Application Gun
Black spray paint
So you drilled into the truck or is that just attacked to bed liner?
J.Bodolay
J.Bodolay
Liner kit used: 4 Liter, Black. (couldn't tell you which one of the variations). Bottles are designed to screw into the application gun. 3 bottles is enough to do the bed and rear wheel wells.
Spray over: I pulled the front bed plugs, gate, gate bumpers and the 8 tie down mounts and plugged all the holes. The bed bolts are still removable after coating. (I have only had to do this once on 9 trucks that I lined, but it was doable)
Mounting gear:
a) The Rotopax setup has a pre-drilled mounting bracket that holds the cans. Used the bracket as a template, drilled the box, de-burred and installed washers and aluminum pop rivets.
b) The pioneer gear was painted, and clamped into Quick Fist rubber mounting clamps. 1ea long aluminum 3/16 pop rivet through the clamp and into the side of the bed secures it.
Deleted member 12951
I am going to be doing the rear wheel wells. Do you think one bottle would be enough?
J.Bodolay
J.Bodolay
1 bottle will easily cover the rear wheel wells. Bed and wheel wells could have been done with 2 bottles if I had to. Make sure you have the correct mask/respirator and the best ventilation possible.
