Carbon Fiber Panels
roscopeeco78
Do you need a new door panel with carbon fiber inserts or can you get the CF inserts and put them on existing door panel?
lottp
I believe others found that you'd have to get new door panels. Therefore, they just stuck with the shifter (full shifter assembly) and tray door. Not sure if still the case, but it was also noted that those were sold out.
dinoone
You have to get complete new door panels and it's not worth the money. If you search I posted the part numbers for everything with the exception of the doors. The shifter and sync panel are sold out with no restock to date.
