GEN 2 Installed SVC's Coil Adjuster System
Raptizzle
FYT
Southern CA
Was lucky enough to get in early on the list with the crew at @svc for their new C.A.S. system. Having had two gen 1's previously, the luxury and ease of the perch mod with those trucks is no more. However, it's possibly a blessing in disguise because I had always found myself wanting a ride height somewhere between mid and top perch.
That's pretty much where we ended up at on the install today. Having no reference point, we initially set the adjuster on the conservative side and that put the truck at around mid perch. I also installed 37" K02's with Methods today and there was some minor rubbing but nothing some trimming couldn't fix. So we ramped up the perch on the coilover approximately .5" and that put the front of the truck exactly where I wanted it.
I'm pretty discriminating when it comes to the stance on my trucks so right now my plan is to drop the rear a bit with some Deaver springs and possibly a longer shackle. I'll dial the front down maybe .25" at that time to keep a pretty similar stance to what I have now but just overall lower. Pretty sweet having the ability to make minor adjustments.
Regarding the ride, the truck drives and rides really well with the preload on the spring. The spring rate seems a lot softer on these new trucks so adding preload is way less noticeable compared to middle or top perch on gen 1's. I'm heading to the desert this weekend to devirginize this truck in the dirt so will be reporting back with offroad ride characteristics.
Overall, I'm really happy with how it turned out.
62bf33e89788a2bfb55e2a1049476693.jpgb6b42dda719c960c97366d17c03b01f9.jpg766dfca1dfe1d91af5e78d2af900c1c0.jpg
waddellw
Mississippi
Drop shackle is from what I've heard a bad choice for lift/lower
Raven13
College Station, TX
That looks sweet Tizz!!
