Forscan changes - tweak your truck
Livnitup
SoCal
Only different menu item I've seen so far is the ability to turn Display Off. The font is different and the Blue GT theme seems more polished and scaled for the 8" screen where before it was designed to fit the smaller Mustang screen. I'm sure I'll notice some different things in the days to come though.
dd07
NJ
Engine off, doors shut, you move away with key fob with you
...will the door locks auto lock?
hi guys, is that possible to code?
-thank you
Livnitup
SoCal
So I just entered the following in APIM in Sync 3 v3.0 and it DOES allow viewing of text messages and entering NAV destination while in motion AND Sirius Travel Link is still present and working
APIM 7D0-02-01 5753 xxxx xxxx
This did not work on Sync 3 v2.0 but I never tested it on Sync 3 v2.2 so if anyone is on v2.2 and wants to test it may work on that version also. If you test it please also post whether Sirius Travel Link still works also.
Sync 3 v3.0 download links
For Sync 3 Units WITH Navigation (2 links for the same thing listed, choose 1):
https://1drv.ms/u/s!AgM4_H5aFPr20m9NrR67iLLwlRIP
https://www.transfernow.net/228qr2r97k2k
For Sync 3 Units WITHOUT Navigation:
https://www.transfernow.net/93c957x2pbbt
xxaarraa
Southlake, TX
Good to know Liv.
Sorry for asking a very noobie question, but is there a writeup on how to flash Sync 3 onto the car?
Livnitup
SoCal
If you have NAV it's easy...just download the file and extract the contents to a blank formatted FAT-32 USB drive and insert it into your truck with key on, engine off with a battery charger hooked up or turn truck on and allow it to idle. After it's inserted you'll see on the touchscreen about 5-10 mins later "updating system software" and it'll then take 25-45 mins to finish.
If you don't have NAV the process is more complicated because it entails breaking up the install into two parts because the APIM doesn't have enough memory to do it in one shot. ** you would think the NAV version would be bigger but it's not, the non-NAV one is bigger **
xxaarraa
Southlake, TX
If you have NAV it's easy...just download the file and extract the contents to a blank formatted FAT-32 USB drive and insert it into your truck with key on, engine off. I recommend hooking up a battery charger beforehand so your truck doesn't shut down to preserve battery charge. After it's inserted you'll see on the touchscreen about 5-10 mins later "updating system software" and it'll then take 25-45 mins to finish.
Thank you, good to know and easy to do since I have 802-A / Nav.
Other than being able to set destinations while in motion, are there any other notable features making this worthwhile? What about android mirror link or something similar?
EDIT: I did some googling and found the following to answer my own question:
https://www.extremetech.com/extreme...ster-if-not-standing-out-from-the-competition
https://www.digitaltrends.com/infotainment-system-reviews/ford-sync-3-review/
I think I have quick boot enabled via forscan, I assume that will have to be redone after reflash. Other forscan changes to other modules should be still OK correct?
hmgt3
Thanks for the info. If I don't have a battery charger handy can't I just have my engine running to avoid the battery being drained and shutting off?
Sent from my G8142 using Tapatalk
Livnitup
SoCal
This won't affect any changes you've done with FORScan in other modules. This APIM value change I posted also allows viewing & replying to text messages while in motion & Sirius Travel Link still works (in Sync 2 it wouldn't work with this change)
Yes, you can have engine on and idling during the process
guernsej
Is v3.0 eventually going to be released and available for wireless update, or does that only work for 2.x updates?
