(the One and Only) Tire size.. (thread)
Shaggy
Administrator
Staff member
Admin
Arizona
What is the biggest tire that can fit on stock?
Yes, I said it. :crazy:
pirate air
will plunder your booty
35" diameter by 12.50" width. Anything larger will rub pretty bad on compression. The stock tire size rubs the inner fender wheel wells as is. Keeping the stock wheel back space and width helps prevent rubbing as well.
37 inch tire will rub and probably remove your fender wells for you on full compression.
bstoner59
does it come in shmedium?
Orange, CA
Yes please...maybe you can create an Abyss and put all gas mileage, tire size and 5.4 vs 6.2 threads in there so we never have to read another one again!!
Shaggy
Shaggy
Administrator
Staff member
Admin
Arizona
Ha ha. I knew I would see a post like this :roflsquared:
pirate air
x2.
A FAQ or knowledge base section.
BIRDMAN
Birdministrator
Boston
i slammed my tire in to my fender this weekend. stock tires with less offset wheels...doesn't take much
