- Joined
- Jul 2, 2013
- Posts
- 879
- Reaction score
- 1,115
Some of my friends here may know that I added a Whipple Supercharger to my truck in October of 2013. I was somewhat satisfied with the added power but not thrilled, at that time I was building about 9 LBS of boost.
![IMG_5167_zps252a6a6f.jpg IMG_5167_zps252a6a6f.jpg](https://www.fordraptorforum.com/data/attachments/217/217506-cb5d3b95801984ac9453016a369e889d.jpg)
![IMG_3133_zps08834111.jpg IMG_3133_zps08834111.jpg](https://www.fordraptorforum.com/data/attachments/217/217507-37072985b5190d24a032ecd4ebc4d44e.jpg)
The tune that came from Whipple was not suitable to my needs, it had surging issues, shift issues and the list goes on.
I was able to contact a tuner in my area (Jon Lund) from Lund Racing and took the truck to him for retuning. After 3 pulls he was able to increase my torque 170 FtLbs at 3350 rpm, fix the surging and overall the truck ran strong.
I ended up with 530 FtLbs of TQ at 3350 rpm and 429 RWHP; keep in mind that I have 37” tires.
My main gripe was the sudden drop of power after 3350 RPM.
![IMG_3190_zps6a3863e3.jpg IMG_3190_zps6a3863e3.jpg](https://www.fordraptorforum.com/data/attachments/217/217508-a28d7b67f4ccab2a70ead716678d8f62.jpg)
So........like all idiots I wanted more! Nothing exceeds like excess right??
Knowing that the engine was at the upper limits, and any more boost could result in internal failures, I made a decision to have my engine built.
On December 6th 2013 the engine was pulled from my raptor and delivered to L&M Motors in Hatboro Pa.
![IMG_5789_zps2452d348.jpg IMG_5789_zps2452d348.jpg](https://www.fordraptorforum.com/data/attachments/217/217509-a6197dc2add7b4e5e8e246c7e0588706.jpg)
![IMG_5792_zpsa9c69da9.jpg IMG_5792_zpsa9c69da9.jpg](https://www.fordraptorforum.com/data/attachments/217/217510-3a5b2361f494313d5b102233855d36ad.jpg)
![IMG_5839_zps16be3c96.jpg IMG_5839_zps16be3c96.jpg](https://www.fordraptorforum.com/data/attachments/217/217511-10264ce7a251aaf935dffd945c500737.jpg)
Lesson number 1; Be satisfied with what you have.
Lesson number 2.Make sure parts are available before you remove and dismantle a perfectly fine engine.
So, back to lesson number 2!
NOBODY has parts for the 6.2, now I am certain that some of you will say “Livernois has this” and “ Livernois has that”, again, NOBODY has parts for the 6.2.
Here is where I am today, 3 months and 8 days later.
L&M made molds and designed my pistons, the molds, specs and CAD’S were sent to Diamond Racing Pistons and a one off set of Pistons were made for me.
They are .30 over, Ceramic dome, Teflon Skirt with ARP Rings, and .220 wall wrist pins.
The Cams are custom as well, 232-234, the intake lift is 594 and the exhaust lift is 568.
![image_zps9e410329.jpg image_zps9e410329.jpg](https://www.fordraptorforum.com/data/attachments/217/217512-19f6c34e73f117750c1c1a76709688f7.jpg)
![image_zps54fc40eb.jpg image_zps54fc40eb.jpg](https://www.fordraptorforum.com/data/attachments/217/217513-65036ea44729ffc4a99d122080ae4889.jpg)
![image_zps2cdad183.jpg image_zps2cdad183.jpg](https://www.fordraptorforum.com/data/attachments/217/217514-48715c881c9381d97a142651bfaaea8e.jpg)
![image_zpsff5fb36c.jpg image_zpsff5fb36c.jpg](https://www.fordraptorforum.com/data/attachments/217/217515-aec4729eed1e3b628b73bbc34b8a9c89.jpg)
The H Beam Rods were made by Manley with 2000 ARP Bolts.
![image_zps9d41b5ca.jpg image_zps9d41b5ca.jpg](https://www.fordraptorforum.com/data/attachments/217/217516-4ebdb01c4a76c5b367ef7dbd1fe0ae01.jpg)
![image_zpsd1360896.jpg image_zpsd1360896.jpg](https://www.fordraptorforum.com/data/attachments/217/217517-188816a8a65c9ddab1a0a16c5e5db58f.jpg)
The rockers were modified
![image_zps6a2a02bc.jpg image_zps6a2a02bc.jpg](https://www.fordraptorforum.com/data/attachments/217/217518-ed13093ffa591304f33755be1c2ae839.jpg)
ARP Main and Head Studs
![image_zps904bfae0.jpg image_zps904bfae0.jpg](https://www.fordraptorforum.com/data/attachments/217/217519-096f36f6fd470920e3ec4c15a43d79e0.jpg)
![image_zpsfa225c96.jpg image_zpsfa225c96.jpg](https://www.fordraptorforum.com/data/attachments/217/217520-caa91360b5a0c37defd92a789f255841.jpg)
![image_zps632e0329.jpg image_zps632e0329.jpg](https://www.fordraptorforum.com/data/attachments/217/217521-b630ca7ee787f9c8e8d6808da78d42d9.jpg)
![image_zpsb6b19626.jpg image_zpsb6b19626.jpg](https://www.fordraptorforum.com/data/attachments/217/217522-b9f47b220a7eb9ad90d8a09cf6e36975.jpg)
Triangle Billet oil pump gears
![image_zpsf71066e3.jpg image_zpsf71066e3.jpg](https://www.fordraptorforum.com/data/attachments/217/217523-58bfd84a02be69d9720884ed22a8e904.jpg)
Other adders are
Ported Exhaust
Oil and piston squirter block offs
PAC Valve springs
Modified VCT Phaser’s.
CBR radiator
Kenne Bell booster fuel pump
Injector Dynamics 100 lb injectors
Transmission Cooler
Drive shaft
Torque Converter
ATI Lower Pulley with 12% OverDrive
![19d89aa4-9b6a-427e-b275-c65cfb49bcc5_zps87868aaf.jpg 19d89aa4-9b6a-427e-b275-c65cfb49bcc5_zps87868aaf.jpg](https://www.fordraptorforum.com/data/attachments/217/217524-cf79fc4a0fe3302e8a21efcf409ee485.jpg)
![image_zps17da1d2d.jpg image_zps17da1d2d.jpg](https://www.fordraptorforum.com/data/attachments/217/217525-4ec5b4ccdb101dc4f3958a6c88809305.jpg)
![image_zps68beaa1c.jpg image_zps68beaa1c.jpg](https://www.fordraptorforum.com/data/attachments/217/217526-3f56364d0924b04601ca6cc89781eabc.jpg)
![image_zps5e56054e.jpg image_zps5e56054e.jpg](https://www.fordraptorforum.com/data/attachments/217/217527-635542173fdd24ae78dad26562f64119.jpg)
![image_zps5cb4310c.jpg image_zps5cb4310c.jpg](https://www.fordraptorforum.com/data/attachments/217/217528-68752776736985e9923d10d38d633e59.jpg)
![image_zps7b4da65f.jpg image_zps7b4da65f.jpg](https://www.fordraptorforum.com/data/attachments/217/217529-5d88ba85a8b7827f1668db26942233e3.jpg)
![image_zps4082cc41.jpg image_zps4082cc41.jpg](https://www.fordraptorforum.com/data/attachments/217/217530-60c6256f0813c7f13610a47cb4e374fe.jpg)
![image_zpsa314f40a.jpg image_zpsa314f40a.jpg](https://www.fordraptorforum.com/data/attachments/217/217531-0250d72018096d64f713f11d9baab317.jpg)
![image_zpsdbaf0009.jpg image_zpsdbaf0009.jpg](https://www.fordraptorforum.com/data/attachments/217/217532-5e6e6acd8c04cb710db17588bdea8503.jpg)
![image_zpsfc83a57b.jpg image_zpsfc83a57b.jpg](https://www.fordraptorforum.com/data/attachments/217/217533-f33d5c8a77442706392a04db85f7301e.jpg)
![image_zps346490bc.jpg image_zps346490bc.jpg](https://www.fordraptorforum.com/data/attachments/217/217534-38817ed602d9cc6ec234e336e44ae426.jpg)
![image_zpsb5557415.jpg image_zpsb5557415.jpg](https://www.fordraptorforum.com/data/attachments/217/217535-09bd62ce5f96958023850746e6fc26d0.jpg)
![IMG_6878_zps181bfd2d.jpg IMG_6878_zps181bfd2d.jpg](https://www.fordraptorforum.com/data/attachments/217/217536-7fe07eb7003696f428931888c5d9e0ee.jpg)
![IMG_6855_zps9639e96a.jpg IMG_6855_zps9639e96a.jpg](https://www.fordraptorforum.com/data/attachments/217/217537-f826d3fcc82fc03e8cbaa26fc272d272.jpg)
Other adders are
Ported Exhaust
PAC Valve springs
CBR radiator
Transmission Cooler
Drive shaft
Torque Converter
