TSB 11-5-7 Driveline Clunk
pirate air
will plunder your booty
The CLUNK lol
TSB 11-5-7
05/10/11
RAPTOR - DRIVELINE CLUNK OR CHIRP/SLIP/BUMP
ON ACCEL OR STOP - BUILT ON OR BEFORE
03/12/2011
FORD:
2011 F-150
ISSUE
Some 2011 F-150 Raptor vehicles built on or before 3/12/2011 may exhibit excessive clunk or a chirp/slip/bump condition from the driveshaft on acceleration from a stop or when bringing the vehicle to a stop.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Remove and discard the existing driveshaft assembly. Refer to Workshop (WSM), Section 205-01 Removal and Installation Driveshaft-Rear, One Piece.
2. Install the updated driveshaft assembly. Refer to WSM, Section 205-01 Removal and Installation Driveshaft-Rear, One Piece.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
110507A 2011 F-150 Raptor: 0.4 Hr.
Replace The Rear
Driveshaft Assembly. (Do
Not Use With Any Other
labor Operations)
DEALER CODING
CONDITION
BASIC PART NO. CODE
4841 42
Capcity
Drive Shaft Clunk
Pirate. Attached is what I received when I took my 11 Screw in with the same problem. They ordered the replacement shaft and plan to replace this week.
BIGt0007
CT
Do you have a bigger version?
Yeah please or a link of where to find
---------- Post added at 02:52 PM ---------- Previous post was at 02:49 PM ----------
I've got the clunk in my 2010 why no TSB for that year? It's a 10 and 1/2 with the 6.2
Allied Offroad
Kansas City
I went into the dealership and they told me there was no tsb, and to just grease it, and they would do it for free this time, and i should feel lucky they would do it free this one time...
Capcity
The TSB states that there is a group of driveshafts that did not have nickel plating on the yoke that causes momentary binding. The driveshafts that are approved for replacement are BL3V-4602-AB and BL3V-4602-BB. There is a large part number decal on the drive shaft.
I can email you the TSB if you PM me your email address.
All The Way
Lockport, NY
My 2010 has started to do it on a regular basis now.....I wonder how much of a hassle they will give me about replacing it.
