TSB 11-3-25
03/31/11
6R80 TRANSMISSION BULKHEAD CONNECTOR
SLEEVE LEAKING TRANSMISSION FLUID
FORD:
2009-2010 Expedition, Explorer Sport Trac,
Explorer, F-150
LINCOLN:
2009-2010 Navigator
MERCURY:
2009-2010 Mountaineer
ISSUE
Some 2009-2010 F-150, Expedition, Explorer Sport Trac, Explorer, Mountaineer and Navigator vehicles equipped with a 6R80 transmission may show signs of transmission fluid leakage around the transmission bulkhead connector sleeve.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Verify the leak is present at the transmission bulkhead connector sleeve. With the vehicle in neutral, position it on a hoist. For additional information, refer to Workshop Manual (WSM), Section 100-02.
1. Disconnect the transmission vehicle harness connector by twisting the outer shell and pulling back on the connector.
2. Remove the transmission fluid pan and allow the transmission fluid to drain.
3. Pull the release tab and pull down on the transmission bulkhead electrical connector retainer.
4. With the release tab down, pull the connector sleeve out of the case/mechatronic assembly.
5. Lube new connector sleeve 0-rings with clean transmission fluid, then install connector sleeve into case/mechantronic assembly.
6. Press up on the tab and lock the outer shell of the transmission bulkhead electrical connector sleeve in place. Make sure that the locking tab is securely locked.
7. Install the transmission fluid pan/gasket and refill transmission fluid refer to WSM, Section 307-01 for refill procedure.
NOTE DO NOT TOUCH THE ELECTRICAL CONNECTOR PINS OR THE EXPOSED SOLENOID TABS ON THE TRANSMISSION BULKHEAD ELECTRICAL CONNECTOR. ELECTROSTATIC DISCHARGE MAY OCCUR AND MAY CAUSE DAMAGE TO THE TRANSMISSION CONTROL MODULE (TCM).
NOTE BULKHEAD CONNECTOR SLEEVES MAY COME WITH RED OR BLACK 0-RING SEALS. USE ONLY BULKHEAD CONNECTOR SLEEVE THAT HAS BLACK 0-RING SEAL FOR THIS PROCEDURE.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
110325A 2009-2010 Explorer, 1.7 Hrs.
Mountaineer, Explorer
Sport Trac, And F-150:
Replace Connector Sleeve
Includes Time To Remove
And Install Transmission
Fluid Pan (Do Not Use
With Any Other Labor
Operations)
110325A 2009-2010 Expedition And 1.8 Hrs.
Navigator: Replace
Connector Sleeve Includes
Time To Remove And
Install Transmission Fluid
Pan (Do Not Use With Any
Other Labor Operations)
DEALER CODING
CONDITION
BASIC PART NO. CODE
7G276 D8
03/31/11
FORD:
Explorer, F-150
LINCOLN:
2009-2010 Navigator
MERCURY:
ISSUE
ACTION
SERVICE PROCEDURE
Parts Block
Operations)
Navigator: Replace
Time To Remove And
DEALER CODING
CONDITION
BASIC PART NO. CODE
7G276 D8
