SDHQ Winch Plate with lighting installed - pics!
Dane
Littleton, CO
Just in time for my next trip to the sand dunes, got my latest project completed - An SDHQ winch plate, Elite Viper 12,000 wireless winch, and a bunch of lighting. :party28:
The pic with the plate and lights installed and the bumper off is the WRONG order to install. You can't get the bumper over the lights. Also, you have to cut the outter bottom tabs off (where the lower grill slid in) - bending them just doesn't give you enough clearance.
Dane
Dane
Littleton, CO
More pics
Dane
Dane
Littleton, CO
how is the winch mounted? i want to add one to my truck when i get it. i am looking over ideas now.
The second picture in the first post shows the actual winch plate bolted up with the towhooks. Then there is a fairlead plate that bolts to that plate/frame/bumper. It's this modified to mount the lights to the side - I wanted to take up that empty space with functionality. The winch then bolts down on top of that first plate.
Does that answer your question?
Dane
Dane
Littleton, CO
how hard was the install? i'll be doing this sometime this week. pretty straightforward?
It wasn't too bad. I'm not too much of a mechanic. There were a few tough parts, I'll try to list out the gotchas here.
The bumper is moderately light, but a pain to remove/put back by yourself. The middle of the bumper loves to get hung up on the body plastic in the center both during removal and installation. There are two sneaky bolts in this area near the hood latch in addition to the four large bumper nuts. That's the area that is a real pain.
Make sure you have a 5/8" drill bit - it's not a common size and actually hard to find. The first two 5/8" holes are ok, but the 2nd two (drilling into the bumper once it's back on) are extremely difficult to get a drill into. A close quarter drill is very handy, though mine was only a 3/8" chuck so I had to use the full size drill with the 5/8" bit. It would be optimal to have a close quarter drill that you can use your 5/8" with. I used 3 or 4 different smaller size drill bits as I stepped up to 5/8".
Before you tighten everything down make sure that the holes from the main winch plate line up with the fairlead plate holes well enough to stick bolts through. Mine were ever so slightly off late in the install and I had to go loosen a few things up to align them.
The instructions in mine listed the incorrect sizes for the bumper hardware. I believe the nuts were 21mm and the two sneaky bolts were 10mm (instructions said 18mm and 15mm, online instructions say 21mm and 15mm).
The 1" tab on the bumper that you have to bend or remove must be bent towards the FRONT of the truck, not backwards. I opted to cut it off instead, it's just in the way.
If you have a front license plate bracket with rivets, they are a pain in the ass to drill out. I didn't find any magic trick other than drilling and fighting. Some swearing helped... and a beer. :banghead:
The instructions don't mention anything about what to do with the rubber dust cover. It won't fit back into its original spots with the winch plate installed - not enough slack, though it's close. I zip tied it instead of using the plastic plugs.
95,793
59,476
egermann
