Rough Country Winch Plate & Warn Winch Install
602Raptor
Phoenix, AZ
My previous vehicle was a Jeep TJ Rubicon. I kept the winch when I sold the vehicle with of hopes of transferring it to the Raptor. Here's pics of the install. Let me know if there are questions. I haven't used it yet, but hopefully we'll get snow up north and I can winch out my Jeep buddies. We all know Raptors don't get stuck :)
Overall, I could not be happier with the results.
Parts List:
Warn 9.5ti with 125' of 5/8" steel cable
Warn 73850 steel hawse fairlead for cable
Rough Country 1010 F-150 Hidden Winch Plate
Setup on the bench checking fitments:
attachment.php
Plate installed showing clearances:
attachment.php
It's a tight fit. Will need to open the hood when winching with cable to keep an eye on things:
attachment.php
Sharp looking from the outside:
attachment.php
Thoughts?
602Raptor
602Raptor
Phoenix, AZ
I wheel alone quite a bit and a good winch is a must. Warns are also great winches and you can usually find them on your local Jeep forum for significantly less.
Turk
Nice setup. I've got a Warn 9.5 that I would like to mount hidden like that. Does it affect running temps?
Off to Rough country to see if they have a plate that fits my winch.
I also have an extra 8k, but would rather have the extra power, on a full size truck
Slacker
Alexandria, VA
I am pretty sute the bolt pattern should be identical to just about every other winch out there. They are a standard spread pattern with a standard bolt/thread size.
