billj214
I am sharing my DIY roof rack build as part of a way to contribute to all of you who have shared your projects which inspired me over the years of building things.
OK so the roof rack is for the purpose of:
#1 Because it looks very cool (lets not kid ourselves)
#2 For adding cool looking lights
#3 Quick access location for recovery gear
#4 A place to tie off my hammock when camping!
Supplies:
1" steel tubing 40'
1/2" square tubing 20'
4'x8' corrugate steel
2 pin Deutsche connector (Rigid LED bar)
4 pin Deutsche connector (vehicle connection 2 extra for adding rear lights later).
14g red and black wire
1/4' grommets
2 cans of primer paint
2 cans of truck bed coating paint
Total cost around $140-$150
Frame design up close:
Platform is on top, this is due to the trucks curved roof and allows me to keep the rack as low profile as possible. Middle supports 45 degree angle flat steel, this gives it a unique design and makes the build much easier since making 1' tub spacers takes forever.
Maxtrax mounts:
Since I don't have a winch and these recovery tracks are expensive I wanted to mount them with locking mounts. I will likely only add the studs when I plan a trip, easy to bolt on from underneath. Also the gap on side of corrugated steel was intentional, it allows me to reach mount screws and when using straps on tubing the corrugated steel is not in the way.
Light bar mount:
Nothing fancy but this 1" flat steel keeps the front two bars rigid while adding a mount location.
Wiring:
Self explanatory
Test fit and ready for paint:
Primer and paint with truck bed liner paint, very durable and easily touched up in the future compared to powder coating that chips easily over time.
Installed:
Edit: Trying to update photo links, temp link to album here.
Supplies:
1" steel tubing 40'
1/4' grommets
Maxtrax mounts:
Light bar mount:
Wiring:
Self explanatory
Installed:
